i’ve notices some issues when inserting/importing pdf, text looses its scale completely
This is the pdf i want to insert:
This is what i get into Rhino 6 SR14
I’ve tried several pdf an always get the same result: text completely out of scale
Thanks in advance
kunf
(Kunf)
2
Hello Nachetz
I tried import/insert pdf file and I don’t have issue like you wrote.
Can you attach your pdf, I can have a quick look at this
Many thanks
Dan
Hello!
CAJETIN PLANIMETRIA.pdf (89.7 KB)
I’ve solved this issue importing it with Rhino WIP and saving as but i don’t understand why Rhino6 scales the text
Thanks!
kunf
(Kunf)
4
Hello Nachetz
I opened it on Rhino 6 (last update version)
didn’t have any issues with text.
Maybe is worth to check annotations styles in rhino options.
Check model space scale, because that might be cause.
Many thanks
Dan
thanks!!
i 've just realized it was a units problem, my default file was in meters
Thanks for your test!
