Please zip and send the PDF privately here https://www.rhino3d.com/upload and put a link to this thread in the comments and we’ll take a look. We’ll also need your SystemInfo (run the SystemInfo
command in Rhino). Thanks!
I was not able to reproduce one of the problems, the one in the subject: today running the same command from ui or from command line does produce the same results. I remember trying both sequences after restrting Rhino, and I was getting different results. I guess it was Friday and the different results were in my mind.
The second problem, all texts are good when importing into mm, while some texts are good and some are out of scale when importing into inch, still reproduces.
Here is a quick macro to reproduce the problem. The only commands that matter are New and Import. The other commands are there to make it easy to copy and paste and immediately see the problem.
This works:
point 0,0
-new no "<installation folder>\Template Files\Large Objects - Millimeters.3dm"
-Import "<filename>.pdf" PreserveUnits=Yes PDFScale=1 Unit=inch RhinoScale=1 LoadText=Yes ImportLineWeights=Yes Enter
SetActiveViewport Top MaxViewport selnone seltext selline invert hide
zoom 14,25 5,12
This doesnt:
point 0,0
-new no "<installation folder>\Template Files\Large Objects - Inches.3dm"
zoom 14,25 5,12
SystemInfo
Rhino 9 SR0 2026-6-23 (Rhino 9 BETA, 9.0.26174.12303, Git hash:master @ 8cd1747b0e2a5abafffff683b0f00f4bbe7bf2a9)
License type: Evaluation, build 2026-06-23
License details: Cloud Zoo
Expires on: 2026-08-07
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.9
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Non-hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-19-2026 (M-D-Y). DirectX(11)
> Integrated accelerated graphics device with 1 adapter port(s)
- Windows Main Display is laptop's integrated screen or built-in port
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-23-2021 (M-D-Y).
- Secondary monitor is laptop's integrated screen or built-in port
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY SkylakeX MAX_THREADS=64.
C:\Users\StefanoMenci\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\BlockEditNew\2.1.5\blockeditnew.rhp "BlockEditNew" 2.0.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp "Commands" 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp "3DxRhino.9"
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp "UpdatesAndStatistics" 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp "MeshCommands" 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Import_PDF.rhp "PDFReader"
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp "RhinoCycles" 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp "SectionTools"
This was logged as a private YT because of your files. Here is the ID for future reference. RH-96598/PDF-Import-Inch-Not-Working
The general workaround is:
Import the PDF into the MM template.
Then change the unit to Inches, no need to scale. 1=1
Now zoom in on a dimensioned area.
Select the entire model, scale to line that is dimensioned as 10’-6" to 10-'6" along with the rest of the model.
Now your model is 1:1
In Options → Annotation styles uncheck or disable Layout space scale
(this is common with any imported geometry and annotations that were created outside of Rhino.)
Add and layout and scale the details 1/8"=1’ or 1:96
Hope this helps.
You will be notified here when there is a fix and something to test.
