@stevebaer I see that people have been asking about similar issues since V5 / 2014 - one solution I found was to crank the ‘Rhino PDF’ print resolution up from the standard 300dpi to 1000dpi, however this results in ballooning file sizes if there are raster elements in the document (in my workflow we use a lot of reference photos) - is there a more elegant solution at the moment or is this just ‘how it is’ for now?
Interesting, thank you for taking the time to test that. I’ve run a few more tests and the issue presents itself inconsistently, for example opening the file in Mac recreates the issue, but opening the file in PC and running the same process does not:
