Another question about Rhino Render. Once a rendering is in the works, it seems to freeze the program and you cannot do anything else while it’s rendering. Is there any way to pause the rendering, make a change in the geometry, or lighting and then restart and continue? When I hit the Pause button, it does pause, but when I try to click in any of the viewports to work on the geometry I get the “Cannot be done” bell. What is the point of pausing, friends, if you can’t do anything? ![]()
Also, why is it that you cannot stop a rendering and save it out before it’s gone up to its prespecified samples?
