Pattern shapes to create 3D? Opposite of Unroll Srf
I am very new to Rhino and wanted to know if there was a way to connect shapes to make a 3D surface.
Basically the opposite of what unroll surface does? So if i had 6 pieces of paper connecting them to make a 3D shape would be make the cube, can this be done on Rhino?
Take a look at the command _FlowAlongSurface. You can set a flat surface with the same UV proportions of your 3D surface, and then make your details follow form one to the other.
In the case of a Cube you would have to draw and unrolled cube and so this FlowAlong for each face.
G
@emay Do you want to start with flat shapes, connect along the edges to determine the resulting shape? If so as far as I know there is no simple method to do so.
exactly!
what method would you take to do this?
It’s a tricky challenge, especially if you want to also be able to handle curved developable surfaces, not just flat facets.
A couple of previous related discussions that might be helpful though:
