Passing RhioObject between events after windowsform is shown
Now I am trying to make a command with ModelessForm dialog.
The command is supposed to be like,
  1. Start a custom command.
  2. ModelessForm form dialog is shown
  3. Automatically GetObject method starts.
    4.Transform the object with button_clicked event.
Now, I use “Form_Shown” event for GetObject method.
private void Form_Shown(Object sender, EventArgs e)
var go = new GetObject();
go.Get()
RhinoObject obj = go.Object(0).Object();
The GetObject method works ok that I could pick up some object.
However, I could not find the next way which how to pass the RhinoObject to button_clicked event.
If anyone give me some advise, I would appreciate.
Kato
You can actually save the obj or objectid in a property of your custom command class, then just access the instance of this command and read the propertys value.
eg
public class TestCommand : Command
        public RhinoObject RhObject {get; private set;}
            go.Get()
           this.RhObject = go.Object(0).Object();
            return Result.Success;
and inside your modeless form, something like:
var myObject = Testcommand.Instance.RhObject;
Notice that you have to include a using statement for the TestCommand in this case if they are not in the same namespace.
Thanks Roger!
You saved my life!
