Is it possible to RunScript() from Modal windows forms
Is it possible to post a rhino command while a modal window forms window is open? I am trying to post:
doc.Objects.UnselectAll();
doc.Objects.Select(this.ObjToExport);
string objOptions = Utility.GetOBJOptions();
string fileName = "\\" + Path.GetFileNameWithoutExtension(doc.Name) + ".obj ";
string filePath = this.UnityProjectPath + "\\Resources\\Model" + fileName;
string script = string.Concat("_-Export ", filePath, objOptions, "y=y", " _Enter _Enter");
RhinoApp.RunScript(script, false);
RhinoApp.RunScript("_-SelNone", true);
When I call this from my Modal window it doesn’t execute properly. I can see that _-SelNone gets executed but the OBJ export doesn’t. Ideas?
Does this information help?
http://developer.rhino3d.com/guides/rhinocommon/run_rhino_command_from_plugin/
– Dale
Hi @dale,
I did have proper Attributes for the command:
[System.Runtime.InteropServices.Guid("7cce0799-e273-49c2-ab0b-fe44c5ba3417"),
Rhino.Commands.CommandStyle(Rhino.Commands.Style.ScriptRunner)]
public class UnifyCommand : Command
    public UnifyCommand()
        Instance = this;
Then I was calling the form like so:
            // launch Unify window
            var result = Result.Cancel;
            if (mode == RunMode.Interactive)
                InputData inputData = new InputData(doc);
                var form = new UnifyForm(inputData) { StartPosition = System.Windows.Forms.FormStartPosition.CenterParent };
                var dialog_result = form.ShowDialog(RhinoApp.MainWindow());
                if (dialog_result == System.Windows.Forms.DialogResult.OK)
                    result = Result.Success;
            return result;
Then I would use the form to collect some info from the model and finally try to execute the RunScript() call when user pressed Export on the form.
private void btnExport_Click(object sender, System.EventArgs e)
            this.inputData.ProcessExports();
            // close form
                this.Close();
Where ProcessExports() is:
public void ProcessExports()
            // run OBJ Export
I think I am figuring out what is going on here. It fails because I have a space in my file path that somehow is messing up the command that is being submitted to RunScript()
@dale is there a good way to handle spaces in strings submitted to RunScript() ?
Surround string with spaces with double-quote characters.
// Make sure to surround filename string with double-quote characters
// in case the path contains spaces.
var script = string.Format("_-Open \"{0}\"", filename);
Rhino.RhinoApp.RunScript(script, false);
That works. Thanks!
