Capture subsequent GetObject calls
in my command, I’m asking users to select existing objects from the scene. The selection order is important, so rather than using GetObject.GetMultiple(), I’d like to stack a few GetObject() calls.
The first one works without issues, the second doesn’t trigger, though.
            Point3d startPoint;
            using (GetObject go = new GetObject())
                go.SetCommandPrompt("Select start point");
                if (go.Get() != GetResult.Object)
                    RhinoApp.WriteLine("No start point was selected.");
                    return go.CommandResult();
                startPoint = go.Object(0).Point().Location;
            Point3d endPoint;
                go.SetCommandPrompt("Select end point");
                    RhinoApp.WriteLine("No end point was selected.");
                endPoint = go.Object(0).Point().Location;
            doc.Views.Redraw();
            return Result.Success;
Enabling go.OneByOnePostSelect = true; on the second call forces the input prompt, but disables window selection and users now need to click the objects individually.
What am I missing?
Hi @mrhe,
Maybe this?
  var go = new GetObject { GeometryFilter = ObjectType.Point };
    return Result.Cancel;
  var pointObj = go.Object(0).Point();
  if (null == pointObj)
    return Result.Failure;
  var startPoint = pointObj.Location;
  go.EnablePreSelect(false, true);
  go.DeselectAllBeforePostSelect = false;
  var endPoint = pointObj.Location;
  RhinoApp.WriteLine("Start point = {0}", startPoint);
  RhinoApp.WriteLine("End point = {0}", endPoint);
– Dale
Thanks @dale!
Exactly what I needed!
