After the update around new year, I’ve had the issue of parts appearing translucent in rendered view.
The material is just a stock “metal” archetype with polish at 65%.
Can you paste your Rhino System Information here? Help -> System Information.... Also, is it possible to attach the model here so that we can take a look? If you want to send it privately, use Rhino - Upload to Support.
-David
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17001, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Commercial, build 2022-01-10
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 31Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA RTX A4000 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-20-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 463.02
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-20-2021
Driver Version: 27.21.14.6302
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 4.27.2.0
C:\Program Files\Bongo 2.0 (64-bit)\BongoUI.20.v60.rhp “BongoUI20v60”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.22010.17001
Thanks for the file and the information. Unfortunately, I can’t reproduce the issue with the transparent material. Are you using a viewport display mode with modified settings? If that’s the case, can you export the display mode to a file and attach it here?
You can do it by going to Tools -> Options..., then View -> Display Modes. Click on the display mode you’re using and then Export.
-David
Hi David,
Seems like i’ve fixed it myself.
I copied the exact settings my colleague has, which were identical to begin with, except settings in the “Shadow” tab.
It appears that i had a combination in the sliders that made some parts translucent depending on the angle, i rearranged the sliders to be exactly as my colleague had it, and the problem was gone, peculiar issue.
