himanshu
(Himanshu Walimbe)
September 16, 2018, 9:41am
#1
Only top surface of this filleted box is getting rendered in render viewport. The bottom is solid color of the material (metal)
I’ve tried changing the render settings, mesh settings but no luck.
ATI Technologies Inc.
AMD Radeon™ R5 Graphics
OpenGL version: 4.5.13497 Compatibility Profile Context 23.20.800.512
Render version: 4.5
Shading Language: 4.50
Driver Date: 12-18-2017
Driver Version: 23.20.800.512
Z-Buffer depth: 24bits
Stencil depth: 8bits
Total Video Memory: 384 MB
Is this a hardware limitation?
jesterking
(jesterKing)
September 16, 2018, 9:45am
#2
Looks like the groundplane reflection to me, in which case it is completely expected. Turn off the groundplane and set a different reflection environment to see the material works as it should.
himanshu
(Himanshu Walimbe)
September 16, 2018, 10:06am
#3
@jesterking
Thanks for suggestion. So i switched off the ground plane, added a few objects and a spotlight and here is the result
Is it same if you try rotating the object 45deg in z direction and check the results?
nathanletwory
(Nathan 'jesterKing' Letwory)
September 16, 2018, 12:02pm
#5
You see the studio environment reflection in your cube (and other objects).
Change the custom reflection environment and you’ll see a different reflection.
nathanletwory
September 16, 2018, 12:54pm
#6
This is the RhinoStudio image used, you see the blue encircled part in your vertical surface reflections
This is what you’d see with the Met Balcony NYC
environment set to custom reflections:
himanshu
(Himanshu Walimbe)
September 16, 2018, 3:38pm
#7
Thanks for your replies
Changing the environment is getting the result i desire.
