BEMAD
September 27, 2017, 11:50am
#1
Parrallel detail layout BUG since the last WIP with clipping plane and shadows.
View are not shaded anymore whatever lighning mode (occlusion scene etc…)
SHADING
New WIP
White object such Human just dissapear when not shaded.
Old WIP
By the way we could see sort or “zone” ar line when print in PDF see above picture
WITH CLIPPING PLANE
New WIP
Old WIP
BEMAD
September 27, 2017, 11:39am
#2
Shadows seems to have dissapers with the last WIP in detail layout viewport when parallel projection are used, with occlusion or sun+sky light… is it linked?
BEMAD
September 27, 2017, 12:08pm
#4
POST “Parrallel detail layout BUG”
DavidEranen
(David Eränen)
September 27, 2017, 12:17pm
#6
@BEMAD ,
I will now try to reproduce this bug.
-David
BEMAD
September 27, 2017, 12:38pm
#7
Great let me know if i can help.
DavidEranen
(David Eränen)
September 27, 2017, 12:57pm
#8
I can reproduce the “no shadows” bug. Here is the YouTrack item: https://mcneel.myjetbrains.com/youtrack/issue/RH-41641 .
DavidEranen
(David Eränen)
September 27, 2017, 1:02pm
#9
I think the other problem might be because of the bug I reported.
By the way, what happens if you switch the detail view to Perspective, and then back to your parallel view? For me that fixed the problem.
BEMAD
September 27, 2017, 1:03pm
#10
i haven’t try cause i’ve got several detailview nicely align… but i’ll give a try and let you know
BEMAD
September 27, 2017, 1:12pm
#11
A bit tricky but seems to work… i had to move the model under perspective view before going back to ortho to get it update…
DavidEranen
(David Eränen)
September 27, 2017, 1:14pm
#12
I’m glad the workaround worked. There is still of course a bug here that we need to fix. When that is fixed I will see whether it also fixed the weird clipping plane issues.
Thank you for reporting this.
-David
BEMAD
September 27, 2017, 1:17pm
#13
Also when you zoom or dezoom on the detail view it becomes darker or clearer…
ZOOM OUT
ZOOM IN
