I am new to Rhino and am looking for the easiest ways to create custom “parametric” wall panels/decorations.
The picture below, would be an example of a wall panel that I want to create.
What I am looking for is the easiest way to create these kind of panels, where I create the design in Rhinoceros (including the contours and depth in the design).
Do any of you have recommendations on how to recreate a similar panel? I want to use (for example) curves inside a rectangle to imitate this, or do you have any better solutions?
I have seen some tutorials where i can use for example Scale1D to create curves in a design, but no tutorials where I can use curves and create my own patters, in a simple way.
Any tips, tutorials and recommendations are welcome.
Hi @Timo_de_Lange
This is an algorithm I rather use . You can use first graph-mapper to identify your curve shape (the graph shape is the curve ) . And the second graph-mapper is used to give parametric offset to the points so they look more parametric Wall_Pattern.gh (14.8 KB)
