Parametric shelves along a curve
Hello all,
what is the best way to create this Parametric Shelf?.
I want it to run along the wall (that’s why I chose the curve).
Are there any simple ways? What commands could be helpful? Is there a useful script?
Store.3dm (3.5 MB)
Thanks in advance!!!
shelves V0.gh (22.9 KB)
Adjust the parameters, you will get many shelves.
Omg thank you so much @Quan_Li !
I will try it directly!
How can I chance the verticle tools in this organic, wave shape like in the picture?
Try to adjust the red ones, you will easily find out what they do.
Hello @Quan_Li
I’ve try do change the verticle tools, but
shelves water.gh (44.2 KB)
it does not work.
I would like to have the same shelves in the vertical direction.
How do I get it to work? I have already adjusted the shelves as I need them.
And how do I get the shelves around the curve?
The wall it’s going to be against is not planar, unfortunately.
Store.3dm (3.5 MB)
Add this here.
I try it, but it is not the right direction.
I would like to have the shelves at the respective end.
The problem is, although I have copied the parameters, some error is there
It is perfectly fine at my end, not sure what is the problem.
I need the same shelve in the vertical view. See yellow in the picture.
I don`t understand where my problem ist.
Can you send the file, where it function to you?
And maybe where it is on the curved surface?
Store.3dm (3.5 MB)
this is the curve what I mean
