Parametric Shelf modeling, please help
Hello all,
how can I model this shelf in the picture? (grasshopper script, commands etc.)
Thanks a lot!
Kind regards
Not exactly the same as your reference image, anyway it could be a start for you as you play around with it along.
Bookshelf_re.gh (17.6 KB)
Omg thank you!!
Have you construct it by yourself?
It is amazing!
I have a curved surface. How can I project the “pattern” on it?
this is the curved surfaces where I want to add the parametric shelv.
Rhino File:
grundriss 05.04.2023.3dm (19.6 MB)
Thank you so much!!
I want the shelf in glass ( I need the glass surface und the lines in the command pipe?
so like that
@HS_Kim
