Parametric kerf bend / lattice hinge
I’d like to 3d print a kerf bending or mesostructure material or lattice hinge. I did go through google, trying to find an existing definition to create the “hole” but couldn’t really find it since its an approach though more for laser cutting.
is there an existing definition for creating theses? basically modify the pattern size depending on the thickness of the print for example, or at least create the offset so it actually bends the material? I did try crystallon, but couldn’t really make much out of it.
There is more information or there about this.
Have you seen this thread:
