Parakeet Loading Error - Rhino 7
Can anyone help with this Parakeet loading error?
Command: _Grasshopper
An error occured during GHA assembly loading:
Path: C:\Users\Mark\AppData\Roaming\Grasshopper\Libraries\Parakeet.gha
Exception System.IO.FileLoadException:
Message: Could not load file or assembly ‘file:///C:\Users\Mark\AppData\Roaming\Grasshopper\Libraries\Parakeet.gha’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception System.NotSupportedException:
Message: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
Thanks in advance!
What folder did you place parakeet in?
You should unblock all DLLs you downloaded.
Hi Michael,
I downloaded from food4rhino, unblocked, and copied to GH special folders/ components.
Thanks
Hi Gankeyu,
I unblocked the parakeet.gha and parakeet .gphy. Not sure what Dlls are needed to unblock in this case. Can you advise if I am missing something?
Thanks
