GH plugin error _ System.IO.FileNotFoundException
Hi everyone,
i’ve I plugin written for GH in Rhino 7, everything works fine in my system but when i’m installing it on other systems i have a loading error.
I copy all the bin folder and dependencies .dll on the new system (all files are unblocked). Lunching Grasshopper i receave the following message:
Path: C:\Users\cocoa\Desktop\bin\bin\PhysX.GH.gha
  Exception System.IO.FileNotFoundException:
  Message: Impossible de charger le fichier ou l'assembly 'PhysX.Net.dll' ou une de ses dépendances. Le module spécifié est introuvable.
I checked the loading of assemblies with the windows fusion debug “FUSLOGVW.exe” and comparing it I can find some differences in the log when lunching grasshopper.
The yellow squared log is from the machine working fine. It looks like assembly are loading in a different way and I can figure out why.
Thank you very much for your help
Strange, I’d say it was a blocked library because I had the same problem recently.
Hello, anybody had a similar problem?
Thank you
Is your plugin COFF-loaded or directly loaded?
I don’t know really, i compile it the .dll from VS and i change de file to .gha. In the same folder i copy all the required dll. GH load it at startup. No problems in some systems
Try to add [assembly: GH_Loading(GH_LoadingDemand.ForceDirect)] to force GH loads your plugin directly, which helps with satellite assembly resolving sometimes.
OK i will try today, thank you for your help, i search your code in the forum and I found this old topic from David Rutten that seems to me related in some way
How to define per-GHA loading mechanism? - Grasshopper
Hello @gankeyu, i still have the problem… i think the plugin already was loaded by disk. I still can’t load it because the reference assembly is missing.
Any helps from someone in the forum? I can’t find any difference in the two systems (same rhino, gh, framework, win) and still not working.
Thank you
Hello to everybody, two years ago and i’m still stucked here. No way to load the plugin to other systems i can’t understand what dll is missing.
fuslogvw log is looking ok and the .dll is loaded
I checked it with dependency walker and this is also ok,
thank you for any help
