Just a thing that anoys me a bit.
If I match properties I do this:
- select object that needs properties
- click the match properties button
- then click the object with the properties
Here comes the paper cut… I can select the object that needs the properties. So object 1 needs properties and object 2 has them. And I can select object 1 as source… Maybe make it not possible to select the object itself?
