Panton Chair - SubD Model Attempt
Ouch, 440 seconds? I have never seen that before and have no idea what causes that. The CPU was released 8 years ago, but should not performe bad. Some machines show som odd, slow results every now and then. Mainly xeons though.
It would have been interesting to see how it would perform on a fresh windows install to figure out if its hardware, software or driver related. I understand that you obviously won’t be reinstalling just to bugtrack, but it would be satisfying to figure it out though :slight_smile:
Did you have any other processes going on in the background?
Only Sticky Notes… would you advise removing anything from task manger in particular? Maybe it’s because using the Windows10 dark mode (for file explorer etc.) or something random like that?
The extract and join render mesh sure is quick though…
Hey, I could give it a shot. The new wheels should be around soon. Especially if it could give some info as to what was up. It wouldn’t be any sticky command settings and stuff would it?
Take 3. I turned off sticky notes :sweat_smile:
In the WIP, better and worse. Life in the old dog?
Thanks for your advice, less the edges. I start from the curve and then SubD loft, the result could be accepted by me.
RH-55559 is fixed in Rhino WIP
