With Pangolin you can create complex steel structural model definitions that include details such as:
- Beam haunches
- Highly configurable cold-formed sections with stiffeners
- Surface loads with load transfer surfaces distributing them onto beams
- Load combinations made up of loads in load cases
- And so on
The created model then can be saved out as a file for later usage or sent directly over to Consteel by the connection component, for analysis with Consteel’s unique calculations.
Currently supported objects:
Geometry: Lines, arcs, polygons
Structural members: Beams, plates, supports, rigid bodies, diaphragms, link elements, haunches Sections: More than 7000 predefined from Consteel section bank, or custom defined by section macros, including cold-formed sections with stiffener definition support
Custom structural attributes: Release stiffness model, support model, material properties
Loads: Nodal, line, uniform and linearly changing surface loads
Load configuration: Load combinations, load groups, load cases, load transfer surfaces
Organization: Layers, and structural groups
I.O: Load from file, load from Consteel, save to file or Consteel
Integrated parameters: For unambiguous definitions, avoiding the use of nebulous generic parameters
Download and details on food4Rhino…
Posted Jun 02, 2020 by Cécile Lamborot on Rhino News, etc.
