I have Rhino 6 updated to the latest version (6.9).
I can not install Paneling Tools “not compatible with the Rhino Installer Engine”
I have already tried with Installer Repair Utility but with no results.
Any tips?
Which version of PanelingTools are you installing? (October 11, 2018)?
Yes October 11, 2018, with no success.
After I tried with April 13, 2018 with no success again…
@brian can you help please?
@lucavsnt can you please post a screenshot of the error?
It will also be very helpful if you can share the “all the text below RECOMMENDED ACTION” in the repair utility.
This is the message…
----- Summary -----
A fix was applied to your computer.
Version 6 (x64) of the Rhino Installer Engine will install packages for Rhino 6 and older.
RhiFix.exe version 6.0.6726.16913 starting…
------Details------
- Detecting Rhino Installer Engine Executable … 6.9.18271.20591
- Detecting Rhino.InstallerPackage registry key in HKLM … 6.9.18271.20591
- Detecting .rhi registry key in HKLM … found.
- Detecting Computed .rhi File Association … 6.9.18271.20591
- Detecting User .rhi File Association (Windows 7) … not found.
- Detecting User .rhi File Association (Windows 10) … not found.
- Detecting 32-bit Rhino 5 … not found.
- Detecting 64-bit Rhino 5 … not found.
- Detecting Rhino 6 … 6.9.18271.20591
- Detecting Rhino 7 … not found.
- Detecting File association mismatch … not found.
- Fixing .rhi registry key in HKLM … succeeded.
----- Data -----
- rhiexec_installed_version = 6.9.18271.20591
- rhiexec_install_path = C:\Program Files\McNeel\Rhino Installer Engine\x64\rhiexec.exe
- rhiexec_exists = True
- rhiexec_platform = x64
- rhi_system_registry_open_command = “C:\Program Files\McNeel\Rhino Installer Engine\x64\rhiexec.exe” “%1”
- rhi_system_registry_open_command_path_exists = True
- rhi_system_extension_registry_key_found = True
- rhi_system_extension_registry_class = Rhino.InstallerPackage
- rhi_file_association_exists = True
- rhi_file_association = C:\Program Files\McNeel\Rhino Installer Engine\x64\rhiexec.exe
- rhiexec_associated_version = 6.9.18271.20591
- v5x64_version = 5.2.30328.21415
- newest_rhino_version = 6.9.18271.20591
- v5x64_install_path = C:\Program Files\Rhinoceros 5 (64-bit)\
- v5x64_install_path_exists = False
- v6_install_path = C:\Program Files\Rhino 6\
- v6_version = 6.9.18271.20591
- v6_install_path_exists = True
I’m guessing that your download of PanelingTools is corrupt.
There should be a log file on your computer telling us what’s wrong. Here’s how to find it:
- Open My Computer
- In the address bar, paste
%APPDATA%\mcneel\rhinoceros\6.0\logsand press Enter - Sort the list by date
- Find the newest log with PanelingTools in the name
- Post the log here.
Thanks
10/16/2018 20:26:46 10800 Info Start: rhiexec
version 6.9.18271.20591
64-bit
unknown 10.0.17134.0
10/16/2018 20:26:46 10800 Info arguments:
"C:\Users\Luca Visintini\Desktop\PanelingTools2018101100.rhi"
10/16/2018 20:26:46 10800 Info Logging started: 2018/10/16 20:26:46
10/16/2018 20:26:46 10800 Debug Unknown InstallerDialog_Load starting (0%)
10/16/2018 20:26:46 10800 Debug Unknown InstallerDialog_Load ending (0%)
10/16/2018 20:26:46 10800 Debug Unknown ShowInitializationDialog starting (0%)
10/16/2018 20:26:46 10800 Debug Unknown ShowPanel starting (0%)
10/16/2018 20:26:46 10800 Debug Unknown SwapPanel starting (0%)
10/16/2018 20:26:46 10800 Debug Unknown ShowInitializationDialog ending (0%)
10/16/2018 20:26:46 10800 Info Initializing INIT START: (0%)
10/16/2018 20:26:46 10800 Info Unknown Package not recognized as Localization Package (0%)
10/16/2018 20:26:46 10800 Info Initializing Initializing Installer (0%)
10/16/2018 20:26:46 10800 Info Unknown Found 1 plug-ins (0%)
10/16/2018 20:26:46 10800 Debug Unknown Executing 32-bit Plug-in Inspector for 'C:\Users\Luca Visintini\AppData\Local\Temp\rhiexec\5ddf0b4e-a5bb-4628-856b-05613c3d1f84\PanelingTools.rhp' (0%)
10/16/2018 20:26:46 10800 Debug ExecuteChildProcess starting: x86, /INSPECTPLUGIN "C:\Users\Luca Visintini\AppData\Local\Temp\rhiexec\5ddf0b4e-a5bb-4628-856b-05613c3d1f84\PanelingTools.rhp"
10/16/2018 20:26:46 10800 Debug Starting: C:\Program Files\McNeel\Rhino Installer Engine\x64\..\x86\rhiexec.exe /loglevel=Debug /logfile="C:\Users\Luca Visintini\AppData\Roaming\McNeel\Rhinoceros\6.0\logs\PanelingTools2018101100 (20181016-202646).log" /noerrorreports /INSPECTPLUGIN "C:\Users\Luca Visintini\AppData\Local\Temp\rhiexec\5ddf0b4e-a5bb-4628-856b-05613c3d1f84\PanelingTools.rhp"
10/16/2018 20:26:46 5992 Info Start: rhiexec
32-bit
10/16/2018 20:26:46 5992 Info arguments:
"/loglevel=Debug"
"/logfile=C:\Users\Luca Visintini\AppData\Roaming\McNeel\Rhinoceros\6.0\logs\PanelingTools2018101100 (20181016-202646).log"
"/noerrorreports"
"/INSPECTPLUGIN"
10/16/2018 20:26:46 5992 Info Logging started: 2018/10/16 20:26:46
10/16/2018 20:26:46 10800 Debug Unknown ShowPanel ending (0%)
10/16/2018 20:26:46 5992 Debug PluginInfo::IsValid() returning false
10/16/2018 20:26:46 5992 Debug FinalExit Exiting installation with return code InspctFailed
10/16/2018 20:26:46 5992 Info Logging ended: 2018/10/16 20:26:46
10/16/2018 20:26:46 10800 Debug ExecuteChildProcess complete. Child process returned: InspctFailed
10/16/2018 20:26:46 10800 Debug ExecuteChildProcess starting: x64, /INSPECTPLUGIN "C:\Users\Luca Visintini\AppData\Local\Temp\rhiexec\5ddf0b4e-a5bb-4628-856b-05613c3d1f84\PanelingTools.rhp"
10/16/2018 20:26:46 10800 Debug Unknown Executing 64-bit Plug-in Inspector for 'C:\Users\Luca Visintini\AppData\Local\Temp\rhiexec\5ddf0b4e-a5bb-4628-856b-05613c3d1f84\PanelingTools.rhp' (0%)
10/16/2018 20:26:46 10800 Debug Starting: C:\Program Files\McNeel\Rhino Installer Engine\x64\..\x64\rhiexec.exe /loglevel=Debug /logfile="C:\Users\Luca Visintini\AppData\Roaming\McNeel\Rhinoceros\6.0\logs\PanelingTools2018101100 (20181016-202646).log" /noerrorreports /INSPECTPLUGIN "C:\Users\Luca Visintini\AppData\Local\Temp\rhiexec\5ddf0b4e-a5bb-4628-856b-05613c3d1f84\PanelingTools.rhp"
10/16/2018 20:26:46 13036 Info Start: rhiexec
64-bit
10/16/2018 20:26:46 13036 Info arguments:
"/loglevel=Debug"
"/noerrorreports"
"/INSPECTPLUGIN"
10/16/2018 20:26:46 13036 Info Logging started: 2018/10/16 20:26:46
10/16/2018 20:26:46 13036 Debug PluginInfo::IsValid() returning false
10/16/2018 20:26:46 13036 Debug FinalExit Exiting installation with return code InspctFailed
10/16/2018 20:26:46 13036 Info Logging ended: 2018/10/16 20:26:46
10/16/2018 20:26:46 10800 Error Unknown Plug-in inspection failed (0%)
10/16/2018 20:26:46 10800 Error This package is not compatible with the Rhino Installer Engine.
You may need to update to the latest Rhino Service Release to use this plug-in.
DEVELOPERS:
For information on making your plug-in compatible, visit http://developer.rhino3d.com/guides/general/rhino-installer-engine
10/16/2018 20:26:46 10800 Debug Unknown SwapPanel ending (0%)
10/16/2018 20:26:52 10800 Debug Unknown Next Button Clicked (0%)
10/16/2018 20:26:52 10800 Debug Unknown InstallerDialogClosing starting (0%)
10/16/2018 20:26:52 10800 Debug FinalExit Exiting installation with return code Initializing
10/16/2018 20:26:52 10800 Info Logging ended: 2018/10/16 20:26:52
Luca, what is the size of your .rhi file? Want to make sure it is not corrupted.
Here is what I have:
Seems the same…![]()
This is strange. @John_Brock and @BrianJ could you please verify that you can install PanelingTools (10/11) with no problem. Check Loca’s log above to make sure you have similar Rhino version. Thanks
Thanks to everybody. Now it works! I decided to reinstall Windows (also other software had “problems”) and then Rhino. After Paneling Tools. Now I can use it!
Great.
