Panel opening
Hello I would like to open the panels render and the panels environment that can be seen in various tutorials, for tests but I do not find these panels, rhino help indicated me a place to open other panels but some missing, what to do?
Hi @Ludo,
Two places to check out:
  1. The Panels menu
  2. Docked panels container
HTH
Jeremy
Hi @jeremy5
Thank you for your help! While trying the first place I noticed that the command line was entered but nothing opened and in the second place I did not have the same proposed panels or the same number. The panels render, environment and materials remain invisible.
I’m using an educational version of rhino, wouldn’t that be the problem? :thinking:
Hi Ludo -
Could you run the Rhino SystemInfo command and copy-paste the result here?
Rhino 7 SR17 2022-4-12 (Rhino 7, 7.17.22102.05001, Git hash:master @ 13b57035af8fb22da005ef72c56e4555d9dbcfe3)
License type: Éducation, version 2022-04-12
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 15Gb)
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 5-5-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1650 Ti (NVidia) Memory: 4GB, Driver date: 10-20-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 496.49
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-20-2021
Driver Version: 30.0.14.9649
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
No, there’s no difference in features.
Could you post a screenshot of the contents of your Panels menu?
Here is the screenshot of panel menu. On this panel the functions material, environement, texture and rendering are displayed but unusable
Hi - In the Plug-ins page in the Rhino options, is the RDK loaded and enabled?
Yes I believe the thermal RDK corresponds to that I framed?
RDK rhino option
Beacause is the only place where this name appears.
In addition, all plugins are activated except “Renderer Development Kit UI”
You need that to be enabled.
EDIT: And then restart Rhino
It works!! Thank you very much! :grin:
