Certain Panels Will Not Actually Open
I’m struggling to find a current solution even though I’ve checked most forums that seem to correlate to this issue.
I click on certain panels i.e. Lights, Named Views and they do not open. It runs the command, though there seems to be no output, there’s no floating panel window at all.
please open rhino, run the systeminfo command and post the result-
Rhino 7 SR16 2022-3-8 (Rhino 7, 7.16.22067.13001, Git hash:master @ aa7902c94c5aa33511e60d30f82b636be43bc85f)
License type: Evaluation, build 2022-03-08
License details: Cloud Zoo
Expires on: 2022-05-05
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-16-2020 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 10-20-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 496.49
Integrated accelerated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-20-2021
Driver Version: 30.0.14.9649
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\dicks\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21250.810
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.16.22067.13001
try making the laptop monitor your primary screen and extend to the plug in as the secondary… having the plug in as the main causes all sorts of weird graphics glitches.
no apparent effect after setting the laptop as primary screen.
The issue still occurs, even without the monitor plugged in. It runs the command and then nothing happens after that. no tab or window pops up.
it also doesn’t show up as apart of the docked tools on the right hand side (No Lights / Named Views Panel)
Here’s what the systeminfo command shows after disconnecting the monitor:
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Render version: 4.6
C:\Users\dicks\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hi Kai -
So, if you run the NamedView command from the command line, it just runs that but no panel shows up?
What if you disable Enscape in the Plug-ins and restart Rhino?
Got It!
Turns out the issue wasn’t enscape, but RDK Plugin which for some reason was turned off
