As a prolific user of 2 Point Perspective I’ve found frustrating the impossibility of moving the camera vertically… I usually need to “show camera” and then moving manually the target vertically (which is very laggy btw)…
Am I missing something? A quicker/easier method?
To change the camera Z location you can use Ctrl+up or Ctrl+down
i’ve tried in the viewport while in 2pp mode, not working…
Something may be wrong with your Rhino? I am not sure
should i select something before the Ctrl+up /down command? Could you describe the procedure?
select nothing and press Ctrl + arrow up/down
Correct, 2PP mode in Rhino has some limitations.
You can try this tool to manage it better:
hth,
-j
it works perfectly…
Still, what a shame this cannot be done directly from Rhino…
thanks!
