Orienting a spiral curve along a curve?
Hi! How do i orient this spiral along this shoe shaped curve?
use the Flow Command
Rhinoceros Help - Flow | Rhino 3-D modeling (mcneel.com)
Hi Dwayne - Helix has an AroundCurve option that may shortcut the process for you.
Thanks! That did work somewhat but there was jagged edges for some reason when I did it. The Helix Aroundcurve method was the perfect solution.
This was a spot on solution. Thanks for your help.
