Orient ellipses on curve
I am having difficulty orientating ellipses on a curve using perp frames. I can’t seem to figure out how to get the ellipses so that I can see the profile instead of seeing the geometry on edge.
I have attached a grasshopper file as will as (1) ellipse showing how it should be oriented that I imported from Rhino.
Any help would be greatly appreciated.
Mark Plaga
elipses on curve.gh (26.1 KB)
is it a modelling or a grasshopper - question ? - you might want to change category for grasshopper.
or point out, that your .gh is just something you want to do by standard rhino commands.
thanks for the clarification. best -tom
Hello - you can create new planes from the perp frames using Deconstruct Plane and Construct Plane-
In this case, you can use HFrames instead of PFrames:
Joseph,
Thanks that did the trick. Thank you very much.
Mark
Tom, Thanks.Yes this was a grasshopper question. Thanks for the info.
Mark
