hope i can explain. I have made a surface split to have samaller surfaces but the list is not in order so I used an sort point to order it, well what can i do now to order the surface split list using the information of the sort points component? I think I have to use the REPLACE ITEMS component but I am not sure. Thanks a lotdiscretizacion.gh (9.5 KB)
it is good, thanks, but i have to use surface split. Do you know how to order the surface split list using de sort points? Thank you
thanks a lot, is it possible to do it with other component instead of list item?
Other than that this is a classic case where sort pts (centers) along curve (ccx plane fit, sphere fit) works and thus … see attached.
discretizacion_v1.gh (13.2 KB)
