Option to export as Illustrator (.ai) - not showing up
My option to export a closed planar curve as an Illustrator file (.ai) is not showing up in the list of alternatives.
Rhino version is:
Version 8 SR18
(8.18.25100.11001, 2025-04-10)
Educational
Windows version is:
10.0.26100 Build 26100
I had access to the export alternative not too long ago, but not anymore and I would like to have it back.
Yours sincerely
Jonathan
Pls check the Illustrator plugin is loaded,
Hi @Jonathan19
First thing to check is - using the PluginManager command in Rhino - that the Adobe Illustrator plugin is loaded:
HTH, Jakob
Thank you Jessesn and Jakob! It was for some reason unticked. Super grateful!
