Opennest v1.0 problem
After nesting one curve is missing. I think it should appear on a new sheet.
Unfortunately I cannot use Opennest 2 since I am using windows 10.
opennest0206.gh (11.2 KB)
geometries are not internalized in your gh file
by the way, I’m also on windows 10 and OpenNest 2 works like a charm!
sorry here is the internalized version.
opennest02061.gh (15.1 KB)
by using 360 rotations you are telling OpenNest to try 360 different angles… that can become a bit time consuming :slight_smile: (but I believe you will eventually get a solution if you let it calculate long enough…)
lowering the rotations to something like 36 (which is steps of 10 degrees) you already get solutions pretty fast:
on a side note, Placement wants integers between 0 and 2 ( https://youtu.be/3u3rXvBOgJs?t=264 )
