Is it possible to set one rotation setting for one set of objects, and another setting for another set?
For example, if I’m building a plywood display box, I might care about the grain direction of the pieces that make up the skin of the box, but I don’t care at all about the grain direction of the ribs inside. If I want to cut them out of the same sheet of plywood, can the grain-sensitive pieces get rotations = 1 and the rest get, say, rotations = 4?
then the trick is to take the initial sheet polylines and subract from those the result of the nesting A, in such a way to create new sheets WITH HOLES ready to receive the nesting B:
the only weird situation my mind is forecasting is if you would need -for instance in the above example- a third brand new sheet: in that case, because we have told opennest the sheets have a hole, I guess also the new one will have a hole
for that reason, I think the B’s sheet component must always to be set to ONE COPY, and if you need to add empty sheets you always do that on A:
