Hello @Petras_Vestartas@Petras1
How can I achieve a good result with large geometries when using 360 rotation? because some elements were lost. why this happen?
When combine freeform and rectangualr shapes, I think It would be beneficial if Rotation could accept up to 2 values (the first value for any shapes and an optional one for rectangular shapes). or any idea to restrict the rotation of the rectangular shapes?
I did a manual nesting with this example, I would like to try your best result to try with more elements (similar shapes).
Thank you again Petras, for this awesome tool!.
P.S. I suggest increasing the ‘Spacing’ value from zero to leave room for a cutting tool? P.P.S. Given the size of your parts, a ‘Spacing’ value of 20 was needed before I could notice the gaps.
With ‘Rotations’ = 90, ‘Iterations’ = 60 and the default ‘Seed’ = 1, I got this, which sure looks like it could easily be only four sheets instead of five.
Increasing ‘Iterations’ to 90, decreasing ‘Spacing’ to 15 and changing ‘Seed’ = 1, there is no improvement, yet time goes up from 56 seconds to 1.7 minutes!
