OpenNest - Problem with Nesting Perforated Parts
Hello everyone,
After a lot of effort, I managed to get OpenNest working properly for non-perforated parts. However, I’m unable to achieve the same result when working with perforated parts.
The issue is that OpenNest recognizes the outer contour of a perforated part as one separate piece, and the inner contour (the hole) as another separate piece.
What I’m trying to achieve is:
  • To have perforated parts nested as a single, solid piece (outer and inner curves treated as one object).
  • Additionally, if a hole is large enough, I’d like smaller parts to be nested inside that hole.
I’m attaching two files:
  • One contains my original parts.
  • The other shows the desired result, which I achieved using another software (that I currently don’t have access to).
Could you please help me figure out how to achieve this in OpenNest?
Thanks in advance for your time and support! :folded_hands:
Nested Parts.3dm (2.6 MB)
Parts.3dm (2.6 MB)
I’ve had similar issue, but on the food4rhino page there are examples with this situation that can help fix it, I don’t have the file I used to make it but if I am not mistaken, you can group the contours before entering the nesting node and they will stick together.
