I have a series of groups How can I nest it with Open Nest
open Nest.gh (314.8 KB)
Rectangle is not accepted as a curve type for the sheet input. You could simply use Curveparameter.
That’s strange, I always use a rectangle as sheet input
Ah, my bad. Rectangle also works. It seems the solver just don’t like curves that are not closed…
open Nest_re.gh (312.5 KB)
Kim thanks but what about my tags and perforations?
I would like nesting like the original group is it posible? maybe I need to apply another way like de minute 0:53 https://vimeo.com/365514382 , I just would like avoid bake and iniciate another process in case of make some changes.
You need to find the biggest enclosing curve of your polylines and nest it without inner parts. After nesting you have to transform those parts separately using transform output.
Maybe this helps
