OpenNest not showing any results
Hi everyone,
I’m having trouble getting OpenNest to work. I can’t run any nesting operations, as I consistently get the following error:
System.DllNotFoundException: Unable to load DLL 'nfp_nest' or one of its dependencies: The specified module could not be found. (0x8007007E)
at NfpNest.NfpNestWrapper.nfp_cancel_reset()
at nest_lib.rhino_example.run_cpp()
at nest_lib.rhino_example.run(Int32 max_iterations, Int64 max_time_in_seconds)
at nest_lib.rhino_example.static_solver(nest_geo& geometry)
at opennest_2.component_nest1.RunSolve(Int32 myGen)
I’ve also tried running the sample files provided with OpenNest, but I’m experiencing the same issue.
OpenNest was installed and updated through Rhino’s PackageManager, so I believe I’m using the latest version.
Has anyone encountered this issue or have any idea what might be causing it? Could it be a missing dependency or a configuration issue?
Any help would be greatly appreciated. Thanks in advance!
opennest_error.gh (1.3 MB)
Hello
did you look at other discussion on this subject ?
If no you should.
It could be this
