OpenNest : Nest each branch on its own sheet
Hi everyone,
I am trying to Nest geometries on each branch on their own sheet.
Please help me identify what I’m doing wrong. See the .GH file attached
OpenNest - Nest each branch on its own sheet.gh (212.1 KB)
@Petras_Vestartas @inno
Thank you in advance
Regards
Vhuhwavho
Did you first try simple example files from food4rhino?
No i havent, i will go check it out now
Thank you!
I found the solution on the example files,
but i have another issue the INPUT attributes data tree is not matching with the OUTPUT data tree which is affecting parts tagging
The output datatree does not match. This needs to be updated by a new version, I will try to find time for this…
Thank you for the feedback and for your continued effort in improving OpenNest.
