Opening Large V6 File Hangs
I have had a problem with Rhino V7 hanging while opening large V6 files. Rhino just sits there with a big white spot. I presume there is some dialog box that wants to be displayed.’
I’ll try to upload and link to here.
Does Import of the same 3dm into a new document hang as well?
No. They open fine when imported. At least for the several I have tried.
Thanks for checking that. Can you private message me one of the files? My guess is that there’s a display mode the file was saved in that is causing the hang and Importing gets around that.
My suspicion as well. How do I sent it to you? I uploaded on to tech support. I’ve got some more.
https://www.rhino3d.com/upload making sure to add comments, your email address and the file or message me here on the forum. Include the results of your SystemInfo command as well from within Rhino.
