We’ve been porting our Windows plugin to ETO so that we can now easily create both OSX and Windows versions of our plugin. So far we have it running great under OSX Rhino 7 however have hit a problem with Rhino 8.
Rhino 8 release build appears to have moved entirely to Metal and our rendering code (C++) is all OpenGL based. I was hoping there was a “switch” somewhere in the settings where we could make the OSX version of Rhino 8 revert to OpenGL. Confusingly under the settings in Rhino 8 there’s lots of options for toggling settings in OpenGL.
Is there a straightforward way to get our OpenGL pipeline working in Rhino 8 on OSX or are we looking at a complete rewrite to move to Metal?
There is an unsupported and undocumented switch back to legacy OpenGL with the TestMetal command. I don’t recommend using it and we can’t really support it. OpenGL drivers on Mac have been historically difficult to work with and they seem to have gotten even more troublesome with the Silicon based Macs that Apple ships these days.
Using metal on Mac is really the way to go. We may be able to help here by providing some more functionality in our SDK. It is probably best to work together to try and figure out how to minimize the amount of GPU specific work you would need to do. Maybe we could set up a meeting for this.
There are two parts to GPU technologies; the C++ CPU side code that works with metal and opengl to define how the system works and then shaders written in GLSL or metal shading language to run as small programs on the GPU. There are tools to convert shaders to different languages, but in reality that is not the hard part at all. We probably had to spend three weeks rewriting our shaders from GLSL to metal and then spent three years getting the CPU part done.
Fortunately things are working for your computer Rhino 7. Our experience is that in Rhino 7 a majority of the crashes and other other significant display oddities were due to Apple’s OpenGL drivers. They deprecated OpenGL quite a long time ago and we finally had to make the leap over to Metal.
