Hi all,
I just realized that on the daily I am completing the task of drawing a bunch of curves as guides just to be trimmed back into the single open curve I truly need for projecting onto a surface or cutting through a solid, or whatever.
CurveUnion_v01.3dm (72.8 KB)
Instead of copying the ‘pink guidelines’, that I’m wanting to trim, to a new layer (I like to save my unedited guidelines on their own layer) and then hiding the ‘pink’ layer to proceed trimming the ‘blue desired curve’ and joining it all together, it would be great if there was a tool similar to CurveBoolean that when you activate it after selecting all the ‘pink guidelines’ Rhino would provisionally treat all the ‘pink’ curves as individual segments split by all the intersections that it finds and then I could proceed to select/highlight each individual segment and then hit join/boolean and voila, I have a new curve (open curve) that I could put on a different layer.
One issue might be that where the arched curve was split it will forever have a control point at that split…
I don’t really know if that makes the process quicker, but something about the current process seems outdated. Apologies if this idea/thought was a waste of everyone’s time. Cheers
