I want to 3d print a text as a continuous solid block so I tried the following approach:
- use “TextObject” command to create the text curves
- Move the curves so that they overlap
- Select all the curves and run “Join” command
The last step (i.e joining curves) is what is causing me trouble. I am getting “can’t join closed curves” message.
Right now I am having to manually trim the overlapping curves to achieve this. But I was wondering if I am missing something basic here. Is there a simpler way to do this? What I was hoping was a join or boolean curves like the way BooleanUnion works on surfaces…
