Hey everyone, I’m trying to join curves and redefine it as 1 curve. Can anyone help me what tool to use for this? I’ve tried curve Boolean but it’s not working. Thankyou!
Hello- if the curves are all closed and only touch at a point where they are tangent, there is not a way to combine them. They would need to intersect for CurveBoolean to be of use. If you move them slightly inward or scale the larger circles slightly so that they fully intersect then CurveBoolean can help.
Note the inner circles will still be separate but you can make a Hatch from all the outlines - depends what you’re really after.
It’s not clear what you want to do with the radial line… Feel free to post a file with the curves and some indication of what you’d like - are you, for wexample, thinking of these as thick/wide curves?
well in his case that actually would work since they leave a gab in between, here a reduced example with 3 circles.
@CALLISTA_FRITZIE_CHR there is no way for anybody to find out from your drawing, CurveBoolean should work, it might not work when they would not clearly intersect or touch.
please post your file
