I’m using Rhino 8 on Mac and I’ve made a bunch of layouts that I can’t access. They all show up in the ‘layouts’ window but when I try to ‘set as current’ nothing happens and the layouts don’t get added to the bar at the bottom of the window. The only time I can get to a layout is when I click on the ‘layouts…’ at the bottom of the window but that is the only one I can access. Has anyone run into this problem before and how did you fix it?
I could not reproduce the issue you are seeing. It might be model related. Can you repeat this issue in a simple file? If it is model specific, it would help sending the model. Confidential and/or to big ones can be uploaded here
This is happening with all my models at the moment, not just the specific project. I may have to try reinstalling…
I’ve attached a new project that I made which also has the same problem for me. I made two new layouts and once I add a new layout, I can only see the new layout so in the attached file, I can only see Page 2.
The layouts in that file were working before but I moved to a new workstation and this is the first time i’m noticing this. I checked all the other files and none of the layouts in those work either. Unfortunately, I’m the only one with a Rhino license in the office so I can’t ask someone else to open it for me to see if it’s a file issue or something with the installation.
I’m able to switch between layouts in the file you posted, so this is not a file issue. Please run the Reset command, click the Save Settings for Support… button, and then do a “Factory Reset”. Does that make a difference?
I see you are in the same time zone as the Seattle office, so you can use the chat function on the web site or call the office during working hours.
