Im hoping someone can help. After having some issues with a grasshopper script I had uninstalled and reinstalled Rhino 8 on my Macbook Pro running Sequoia 15.0.1. After doing so Rhino layout seemed to not work correctly. I add a detailed view to my page and create the view I wish. After doing so I zoom into the page, in which the detail view should not move and I can add text, but for some reason the detail in the model space moves around. After this happens I am weirdly able to somewhat control the model space when I shouldn’t be, zooming in will move the detail left and zooming out will move the detail right. Attached is a video of what happens when I try to zoom in on plans. This has only been an issues after reinstalling Rhino, I have never had an issue like this before hand.
Hi Japhy,
Attached is the SystemInfo and a copy of the file I first noticed issues on. The troublesome part is, is that if I share the file to someone else it behaves as it should. My software is the only one having issues. I have opened new files and I still come across the same issues. Since posting my first post I have reinstalled Rhino 8 once again as a last ditch effort and I opened a new file in which “Layout 1” behaved normally. “Layout 2, 3, 4 etc” then had the same issues as before.
To conclude above, my Rhino Software is the only one that is having issues, and after reinstallation one layout on a new file worked, but the rest have the reoccurring issue. If needed I can provide a longer video of the issue I will just have to break it down due to size limits.
I’ve tried this file on a similar machine and, as you say, this works fine here.
I’d try to use the Reset command to see if that makes things better on your end.
