Hi, I need to set the ON_StandardDisplayModeId (to ON_StandardDisplayModeId::Shaded) at a CRhinoObject (Rhino5 and Rhnio6 both).
Is it possible, how?
Thanks
Teo
Hi @ceruti,
This works in Rhino 6:
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
CRhinoGetObject go;
go.SetCommandPrompt(L"Select objects to set to shaded display mode");
go.GetObjects(1, 0);
if (go.CommandResult() != CRhinoCommand::success)
return go.CommandResult();
CRhinoView* view = RhinoApp().ActiveView();
if (nullptr == view)
return CRhinoCommand::failure;
ON_DisplayMaterialRef display_mat_ref;
display_mat_ref.m_viewport_id = view->ActiveViewport().VP().ViewportId();
display_mat_ref.m_display_material_id = ON_StandardDisplayModeId::Shaded;
for (int i = 0; i < go.ObjectCount(); i++)
const CRhinoObjRef& obj_ref = go.Object(i);
const CRhinoObject* obj = obj_ref.Object();
if (nullptr != obj)
CRhinoObjectAttributes attributes = obj->Attributes();
if (!attributes.FindDisplayMaterialRef(display_mat_ref, &display_mat_ref))
attributes.AddDisplayMaterialRef(display_mat_ref);
context.m_doc.ModifyObjectAttributes(obj_ref, attributes);
view->Redraw();
return CRhinoCommand::success;
– Dale
Great. Now is ok.
Only a last problem: I can’t set the correct color:. I
CRhinoObjectAttributes m_attr = m_p_obj->Attributes();
m_attr.m_color = ON_Color(255, 0, 0);
if (!m_attr.FindDisplayMaterialRef(m_display_mat_ref, &m_display_mat_ref)) {
m_attr.AddDisplayMaterialRef(m_display_mat_ref);
RhinoApp().ActiveDoc()->ModifyObjectAttributes(m_p_obj, m_attr);
Can you help me?
Thanks
Sorry, I can.
Thanks anyway.
