DisplayMode disappeared from ON_3dmObjectAttributes in WIP
I am corrently working on porting Rhino5 Plugins to Rhino 6 WIP and I have found that
the DisplayMode() previously defined in the object attributes like
// OpenNURBS objects can be displayed in one of three ways: wireframe,
// shaded, or render preview. If the display mode is ON::default_display,
// then the display mode of the viewport detrmines how the object
// is displayed. If the display mode is ON::wireframe_display,
// ON::shaded_display, or ON::renderpreview_display, then the object is
// forced to display in that mode.
ON::display_mode DisplayMode() const;
void SetDisplayMode( ON::display_mode ); // See DisplayMode().
has disappeared from there in WIP.
Is there a new way to get to the object’s display mode from the objects attributes ?
Thanks in advance
Hi Heinz,
CRhinoViewport::SetDisplayMode exists - just pass it the uuid of the display mode you want to set. If you want to use a standard display mode, then you can find it on the new ON_StandardDisplayModeId class.
– Dale
Hi Dale,
thank you for the reply !
Let me detail the question a bit. The code I am porting is checking the DisplayMode in the CRhinoObjectAttributes as well as in CRhinoViewport, to find out how the object is actually displayed:
if ( pAttr.DisplayMode() == ON::shaded_display || ( pAttr.DisplayMode() == ON::default_display && m_pVP->DisplayMode() == ON::shaded_display ) …
Is it correct to say that it is now enough to check the display mode in the CRhinoViewport, because there is no longer a display mode in the CRhinoObjectAttributes ?
Thank you
Heinz
Hi @Heinz1,
Given:
ON_UUID shaded_id = ON_StandardDisplayModeId::Shaded;
If you want to know if a viewport is set to shaded display, then you can do this:
if (view->ActiveViewport().View().m_display_mode_id == shaded_id)
  // TODO...
If you want to know if a viewport’s display attribute supports shading, then you can do this:
if (view->ActiveViewport().DisplayModeIsShaded())
  // TODO...
If you want to know whether or not an object’s display mode is set to shaded display, then you can do this:
if (obj->Attributes().FindDisplayMaterialId(view->ActiveViewportID(), &shaded_id))
  // TODO...
Does this help?
– Dale
Hi Dale,
thank you very much, I think this should solve my case !
Heinz
