Plugin set an individual object to wireframe
Is it possible for a plugin to set a rhino object to be wireframe while other objects remain shaded?
I’m using C++ SDK
I don’t know C++ but can you access SetObjectDisplayMode Rhino command.
SetObjectDisplayMode is what users use for this feature in Rhino.
In C++ you would get a CRhinoObject and a CRhinoViewport. For the CRhinoObject you would add aan ON_DisplayMaterialRef to the object’s attributes with a given viewport Id and the id given by
CRhinoDisplayAttrsMrg::WireFrameModeId();
CRhinoObject* pObject = ... CRhinoObject you got from somewhere...
CRhinoView* pView = RhinoApp().AcitveView();
if( pView )
  ON_DisplayMaterialRef dmr;
  dmr.m_viewport_id = pView->Viewport().ViewportId();
  dmr.m_display_material_id = CRhinoDisplayAttrsMgr::WireFrameModeId();
  CRhinoObjectAttributes oa = pObject->Attributes();
  oa.AddDisplayMaterialRef(dmr);
  pObject->ModifyAttributes(oa);
Thanks Steve! Also Michael.
Edit: unfortunately I can’t modify the object since CRhinoGetObject returns a const reference. I’m guessing I have to create a new one or something?
What I’m really after is the ability to convert an input mesh/polyline to a display mode of something like this:
Just use ModifyObjectAttributes on the CRhinoDoc then.
Thanks! This forum has been infinitely more helpful than most dev forums I’ve posted to.
