Hello.
When we enter coordinates, we can omit Z coordinate, but is there a way omit X and/or Y coordinates? If I recall correctly in AutoCAD we could simply separate coordinates with comma, so by not entering a number for specific axis it would simply use current position: 123,,789 = skips Y; ,456,789 = skips X; ,,789 = skips X and Y
Entering 2 (a,b) values will assume the focused viewport CPlane as “graph paper” and set
Perspective (a,b,0)
Top: (a,b,0)
Front: (a,0,b)
Right (0,a,b)
(refer to the two axes in the lower left corner - three axes for Perspective).
On the other hand, in any viewport world coordinates can be entered by prepending a w: _Point w1,2,3 will enter X,Y,Z = 1,2,3 independent of the viewport that has focus.
Thank you for the reply. Unfortunately, this doesn’t answer the question, since in all cases both A and B coordinates required. I’m working with flat models (top view), so changing view won’t work.
Sometimes I need to move an object at specific Y (or X) coordinate (or draw an ortho line to specific coordinate in one of the axis), as a work around I draw an ortho line from 0 of irrelevant axis) and move object perpendicular to it. This is like 3 times more time-consuming vs simply entering coordinates…
Perhaps this could be a feature request to be able omit axis coordinates or use a placeholder per axis, like c (for current): c,456,789, c,c,789 or even “relative” per axis: r0,456,r0
For example, run this macro _-Move _Pause _Pause _.zx @0,0
and the X and Z coordinates are already constrained when “Point to move to” is awaiting your input.
If you enter a single number, the position of the mouse cursor determines whether the Y coordinate will be positive or negative (per the CPlane) upon hitting Enter.
If you enter a point coordinate, e.g., 0,-10, the Y coordinate will applied per the CPlane regardless of the mouse cursor position. (The X coordinate is ignored.)
