OLE alerts in v7
I found that for some reason Rhino.Runtime.HostUtils.DisplayOleAlerts(false); isn’t respected in v7 is there any particular reason for that? Can I do something about it? It’s a bit irritating as I use the second instance of Rhino in the background and it looks like an error for a typical user.
I’ve just checked v5 and v6 and I don’t see those. Only in v7 - found with 7.9.21222.15001 but I guess this relates to earlier builds also.
@dale would you mind taking a look at this?
This method has not changed between Rhino 6 and 7.
Also note, DisplayOleAlerts will only effect Rhino. Is something else is causing the delay, then this function won’t help.
Can you provide source that that allows me to reliably repeat this? Without, I doubt there is anything can do.
– Dale
Sure. I can’t disclose it here. Please check PM.
