Offsetting 3 sides of a rectangle
Hi Everyone,
I’m working on a 12.379" L x 1.0" x .125" piece to mill out of styrene with 9 small rectangles that will get pocketed and interior profiled. The small rectangles will hold some .125" x .250" rod. I just ran a test and found that the left, right, and bottom lines of the rectangles need to be offset by about 0.015". I don’t want to change the location of the top line as that registers to another part in the assembly. Does anyone have any ideas how I can do this. I have to make ten of these parts. I have attached a Rhino model of the part.
Thanks in advance,
Terry
Test Rectangle for three side offset.3dm (435.0 KB)
Not really sure what you mean…
This is what I see:
Okay, so you want to offset the rectangles by 0.015", but want the top edge not to offset?
There’s probably at least 3 ways to do that.
Somem like this?
Test Rectangle for three side offset_emod.3dm (2.0 MB)
Yes, providing that the black external lines are .015" off from the original. Clear as mud right?
Yeah. I mean depends on how you want to do it. I basically just used offset command, and the gumball tool after by moving the top points back 0.015" to theoretical original location.
But then you’d just have to multi-instantiate it by copy and paste from original instance to the other instances.
And if you wanted to automate that, then you need super duper Grasshopper algos :blush:
But here’s what I think you were after:
Test Rectangle for three side offset_emod.3dm (3.3 MB)
Although, your mill will make inside radius of course.
Hi Terry,
Boxedit is a good tool for doing this quickly. Select all nine boxes and run _Boxedit. In the panel that pops up you need to set the values circled in red below:
When the values are set hit the size increment arrow for X twice (once for each side) and for Y once, then click Apply. The nine boxes will resize and you’re done.
HTH
Jeremy
Awesome! That’s exactly what I’m looking for.
Thanks
That’s cool! :exploding_head: I didn’t even know box edit had that dialogue :sweat_smile: Must be a V7 upgrade :sweat_smile:
That option at the bottom is pretty crazy :smiley:
Jeremy,
I tested one of the strips using boxedit. Wow did that save time. I did the rest of the parts that way. Very cool tool.
Cheers,
Terry
