I am curious how this can occur. I had file created in Rhino 6 that I opened for the first time in Rhino 7. I used curves in the file to create a poly surface.
Then I did OffsetSrf (sharp) 3/4" inward (concave). This failed. It used to work that last time I opened the file.
Created a new file with the same tolerance (1/256) and copied the poly surface to that file. Then I did the same offsetsrf and it worked.
I was wondering how the same operation on the same surface would produce different results in different files with the same tolerance.
Problem OffsetSrf.3dm.zip (80.4 KB)
