The grey polysurface on the right was offset 5 units, and the result is on the left. Not as expected.
(9.0.25343.14055, 2025-12-09)
OffsetSrf Bad.3dm (2.0 MB)
I can fix it, but should not need to.
Command: OffsetSrf
Select surfaces or polysurfaces to offset
Select surfaces or polysurfaces to offset. Press Enter when done
Select object to flip direction. Press Enter when done ( Distance=5 Corner=Sharp ThroughPoint Solid=No Tolerance=0.001 BothSides=No FlipAll )
Surface offsetting in progress… Press Esc to cancel
Creating meshes… Press Esc to cancel
